Scale is broken
Scale is broken
Postby olly » Fri Sep 27, 2013 11:10 am
Scale my drawing for Example 2.5 is broken nothing happend - can somebody confirm this, too?
Mac OSX 10.8.5 QCAD 3.3.2
olly
Re: Scale is broken
Postby andrew » Fri Sep 27, 2013 11:22 am
Thanks for your report. Yes, I can confirm that problem.
A bug report has been created at:
http://www.qcad.org/bugtracker/index.ph ... ask_id=929
Workaround:
Make sure that the button with a chain on it, at the right of the scale inputs is not checked (not pushed), even when scaling with the same factor for X / Y.
