Breakout segment problem?
Postby ostene » Tue Oct 01, 2013 6:24 pm
(159.26 KiB) Downloaded 216 times
Running qcad 3.3.2 I see a problem with breakout segment tool.
I am using Scientific Linux 6.4 and KDE
Attach a small drawing showing 4 segments with problem.
This happens when making an isometric picture.
When I mark one short segment for erasing, next segment is also
erased on the other side of the crossing circle segment.
Is this a bug or?
Re: Breakout segment problem?
Postby andrew » Tue Oct 01, 2013 9:05 pm
Thanks for your report. I've moved this issue to our bug tracker at: ... ask_id=933
Return to “QCAD 3 Troubleshooting and Problems”
