Custom Properties on Maverick
Postby olly » Fri Oct 25, 2013 11:08 am
in QCad 3.4.0 the worked - it's the greatest newbie for me ;-) thank you
3.4.1: I can type the pair, but afterwards they are gone ;-(
olly
Re: Custom Properties on Maverick
Postby olly » Fri Oct 25, 2013 11:14 am
Update only Z is not working !
Z: 10 for example
olly
Postby andrew » Fri Oct 25, 2013 11:21 am
Thanks for the hint.
'Z' is indeed a special case. All properties with label 'Z' are not displayed in the property editor (since QCAD is a 2D CAD and altering Z values would lead to unexpected behavior).
This should of course not apply to custom properties though - I will look into that.
Postby andrew » Fri Oct 25, 2013 12:27 pm
I've created a bug report for this issue at:
http://www.qcad.org/bugtracker/index.ph ... ask_id=957
Postby andrew » Fri Oct 25, 2013 12:30 pm
This issue has been fixed for the next release.
If you are comfortable with editing source files, you can apply the fix to your installed version of QCAD:
https://github.com/qcad/qcad/commit/8da ... 4d1c1bad6a
I.e., change line 521 in file scripts/Widgets/PropertyEditor/PropertyEditor.js to:
if (title==="Z" && !propertyTypeId.isCustom()) {
