QCAD 3.4.5 release problem ...
Postby Husky » Thu Dec 19, 2013 2:41 am
XP32 / QCAD 3.4.5
If I load any of my drawings in the new version of QCAD - I get a Warning window what tells me:
"Grounded 0 recursive block references in blocks:"
After confirming the warning window I can work as usual on my drawings.
Re: QCAD 3.4.5 release problem ...
Postby Husky » Thu Dec 19, 2013 8:38 am
... and trouble to use the library items.
Postby andrew » Thu Dec 19, 2013 10:23 am
Husky wrote:"Grounded 0 recursive block references in blocks:"
Please disable the warnings as dialogs option in the application preferences > command line for now.
Husky wrote:... and trouble to use the library items.
This is likely also caused by showing warnings as dialogs.
Postby Husky » Thu Dec 19, 2013 7:21 pm
andrew wrote:Please disable the warnings as dialogs option in the application preferences > command line for now.
Yep - done.
Additional Note: This not only occur with my own QCAD Drawings - also external drawings are triggering this warning ....
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
