Problem with 1366x768 screen resolution
yai
Postby yai » Tue Feb 04, 2014 9:56 pm
on my new notebook i have opensuse 13.1, gnome 3.10, qcad 3.4.4.0 trial but problems with 1366x768 pixels screen resolution: i don't see the status bar (and other parts of qcad) and cannot resize the qcad window. setting the size in ~/.config/QCAD/QCAD3.conf does not help, qcad always starts with 1200x809 pixels and stores this value in QCAD3.conf when it terminates. Any ideas how i can force qcad to use a different resolution?
Bye,
yai.
to correct this: i can resize the qcad window, but only horizontally.
Re: Problem with 1366x768 screen resolution
Postby andrew » Wed Feb 05, 2014 10:37 am
You might have to rearrange some of the dockable widgets typically available at the right (layer list, block list, property editor, library browser, etc). Try to close them first to see which widget causes the minimum size of the application window to be so big.
yai
Postby yai » Wed Feb 05, 2014 8:27 pm
Hi Andrew,
thänx for your reply. After i removed all those trial components, i can resize the window and after restarting qcad everything works fine!
bye,
yai
Return to “QCAD 3 Troubleshooting and Problems”
Users browsing this forum: Yahoo [Bot] and 1 guest
