Maximum arc length
Maximum arc length
Postby newinwit » Thu May 01, 2014 12:36 am
Dear Forum,
Does QCAD have a limit to the length of arcs?
I am having some trouble making qcad-pro draw very long arcs. Here is the situation: I draw a square with sides measuring, say, 2,000,000 units (inches). Then, using the Arc by 2 Points with Angle Tool, I use the mouse to draw a 90-degree arc from one corner to the opposite corner. The result: qcad starts to draw the arc, but the arc disappears midway to the other corner. I draw arcs just fine with dimensions under a million units. I am using QCAD 3.4.7 on Mac 10.6.8.
Sincerely,
-newinwit
newinwit
Re: Maximum arc length
Postby andrew » Thu May 01, 2014 11:14 am
Yes, I can confirm this limitation (max. arc radius is 1e6).
However, this limit to avoid slow rendering is no longer needed and has been removed for the next release.
Postby newinwit » Thu May 01, 2014 1:42 pm
That explains it. Thanks for the quick reply, Andrew and Clive. I suppose I'll have to forgo the abstract doodling until the next release...
newinwit
Postby newinwit » Fri May 02, 2014 1:54 am
One more thing: Clive, your ellipse trick works like a charm. Thanks!
newinwit
Users browsing this forum: Yahoo [Bot] and 2 guests
cron
