I have run into a problem where as I am attempting to build up an Isometric projection from the parts of an orthographic projection the response of the software is becoming slower and slower to a point where it has almost ground to a halt.
Projection performance
From a QCAD user:
Re: Projection performance
Performance of the projection tool previews needs to be improved:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1052
You can also adjust the number of preview entities under:
Edit > Application Preferences > Graphics View > Appearance > Performance
