I cannot trim/lengthen any polylines. Lines with 2 Points work with these two commands. I think it is similar to this topic viewtopic.php?f=33&t=2775
Systeminfo:
openSuse 13.1 (64bit)
QCAD Version: 3.6.0.0 (3.6.0)
[SOLVED] Trim/Lenghten Polyline Not working
- PolyLine_Lengthen_Problem.dxf
- Polyline trim/lengthen problem example
- (124.02 KiB) Downloaded 408 times
QCad: 3.9.1
Linux Mint: 17.1. Rebecca
Re: Trim/Lenghten Polyline Not working
QCAD doesn't offers a trim tool for polylines.
See the description for the Trim tool:
Trim
Description:
Trims or extends a line, arc or ellipse to another entity
But there is a kind of workaround to solve your problem.
Select the polyline and use the blue Anker to extent to the other polyline. The snap to get it done precisely is "Intersection manual".
Check this out:
Trim
Description:
Check this out:
thank you for the workaround.
Will the trim/lengthen tool work with polylines in the future? Or is it not intended to work with a polyline because of different problems of that type of line?
At the office I work with AutoCad and so I am used to use polylines primarily.
Thank you
pbergaus
Thank you
pbergaus
QCad: 3.9.1
