I just bought QCAD Pro. when I load it it covers the entire screen including the system tray, making it impossible to toggle back and forth between qcad and the manual. Is there a way to re-size it? I am using a Toshiba Tecra M10 with a dual core processor with 2.4 ghz, 4G RAM and 256GB HD.I am running windows vista and Ubuntu 12.04 side by side.(HD evenly split.) unktim
[Edit: Moved to relevant forum by Mod]
too big
Re: too big
Please close some of the dockable widgets at the right (Layer List, Block List, etc.).
Then resize QCAD and enable those widgets you need again, one by one. This should help you to figure out which widget takes too much space on your screen.
With all dockable widgets closed, you can make QCAD as small as 320x280.
Re: too big
I removed all widgets. I cannot remove the trial widget although I paid for the pro version.
Re: too big
You are still using the trial version of QCAD. Please download and install the full version instead.
Please find our detailed instructions for (re-)downloading / updating QCAD Professional or the QCAD E-Book or for downloading an invoice of your order in PDF format on our web site at:
http://www.qcad.org/en/customer-area
You have also received an e-mail with a direct download link in it.
The e-mail subject is '[RibbonSoft Online Shop] Virtual product(s) available for download'.
Re: too big
Andrew,
Okay! I have my pro version and I'm Exploring the book and the program. Thank you so much for all your help. unktim
