line problem
unktim
line problem
Post by unktim » Tue Jul 15, 2014 2:50 am
I bought qcad pro a couple of weeks ago. I have been checking it out and working a couple of exercises. Everything was great until two nights ago. I selected the line from two points. I clicked the first point but as soon as I started to move the mouse it shot out an infinite line. I get the same results with horizontal
and vertical lines. I thought that i might have done something while i was setting preferences but i opened a drawing that i had done a few days before and tried drawing a line from two points and i got the infinite line, so something changed between the time that I drew that drawing and now. I tried everything I could think of. Help! unktim
OS is Windows Vista and The qcad version is 3.6.0
I just discovered something else. I was trying to shorten a line but when I clicked on the line I got a window that said selection is neither a line or an arc.
Moderator
Re: line problem
Post by Clive » Tue Jul 15, 2014 7:21 am
Hi unktim
There are now options to create an X or Ray (infinite lines) when drawing lines and other entities, just make sure you select the correct status when drawing your lines. Next to the line icon you will find the options - select what you need from there.
The Red highlighted is the 'normal' line from 2 points option, the others are X and Ray line options:
Options pic 1.png (4.26 KiB) Viewed 4365 times
You have selected a Polyline, that's why you got the warning dialog window, to break the polyline back down again to single line segments just simply explode it and then try again.
For more information on Polylines Go to - Help > Reference Manual:
Draw Polyline.png (17.03 KiB) Viewed 4363 times
unktim
Re: line problem
Post by unktim » Tue Jul 15, 2014 1:50 pm
Thanks Clive. I did not realize until now that the status bar appeared when you select a line. The ray option was selected. I selected the line segment button and got my line back.
