dwg2svg broken.
kafenio
dwg2svg broken.
Post by kafenio » Mon Jul 21, 2014 1:03 pm
whenever i try to use dwg2svg i get the following error:
Debug: RDwgPlugin::init
Debug: RDxfPlugin::init
Debug: RHelpPlugin::init
Debug: RProScriptsPlugin::init
Warning: RScriptHandlerEcma::eval: script engine exception: "Error: include: cannot read file 'scripts/Pro/arguments.js'"
Warning: "<anonymous>()@:scripts/Pro/Tools/Dwg2Svg/Dwg2Svg.js:24"
Warning: At least one uncaught exception:
i tried this under mac os x 10.9.4 and windows XP - both with the same result. i also tried different .dwgs. QCAD Pro versions tried were 3.6.2 and 3.6.0.
has anyone an idea what the problem may be?
thanks for your help & best regards
k.
Re: dwg2svg broken.
Post by andrew » Mon Jul 21, 2014 1:12 pm
Thanks for your report.
Moved to bug tracker at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1075
kafenio
Re: dwg2svg broken.
Post by kafenio » Mon Jul 21, 2014 5:40 pm
thanks! that was a quick response!
Re: dwg2svg broken.
Post by andrew » Wed Feb 04, 2015 9:52 am
An unrelated follow-up post has been split into a separate topic at:
viewtopic.php?f=33&t=3302
