Spline (Fit Points) corner control not working ...
Post by Husky » Wed Aug 13, 2014 10:01 pm
If I use the "Spline (Control Points)" tool I'm able to control with multi mouse clicks (1, 2 or 3 clicks) the shape of a corner.
If I try to do the same control on the "Spline (Fit Points)" tool it will quit proper working and I can't finish the task. Isn't it designed for that or what is the reason for this behavior?
Just curios: Is a "Spline (Fit Points)" comparable to a Beziér curve?
Re: Spline (Fit Points) corner control not working ...
Post by andrew » Thu Aug 14, 2014 10:08 am
Husky wrote:If I try to do the same control on the "Spline (Fit Points)" tool it will quit proper working and I can't finish the task. Isn't it designed for that or what is the reason for this behavior?
A spline defined by control points can have multiple control points at the same position. The spline then gets closer to that control point.
A spline defined by fit points goes exactly through those fit points. A spline cannot go 'even more exactly' through that point. Consecutive points at the same position lead to unspecified behavior.
Husky wrote:Just curios: Is a "Spline (Fit Points)" comparable to a Beziér curve?
The terms Splines, NURBS and Bézier curves are related but not equivalent. This is a relatively complex topic to broad to cover in this post :?
Post by Husky » Thu Aug 14, 2014 6:23 pm
andrew wrote:
Husky wrote:A spline defined by fit points goes exactly through those fit points. A spline cannot go 'even more exactly' through that point. Consecutive points at the same position lead to unspecified behavior.
Now the dime has fallen ...
Makes sense! :wink:
andrew wrote: ... is a relatively complex topic to broad to cover in this post :?
Yes, of course. Howsoever - thanks for the info! :wink:
