Can´t print
rhenxoff
Can´t print
Post by rhenxoff » Mon Aug 18, 2014 1:50 am
I have Qcad Pro 3.6.3 installed under Win 7 operating system. My printer is a Canon Pixma M140.
I make some draws but i intented print but one blank sheet leave the printer.
How can overcome this trouble?
Re: Can´t print
Post by Husky » Mon Aug 18, 2014 3:54 am
- is your printer properly working with other programs on your system?
- is it possible for you to print pdf's directly with QCAD?
- could you attach an excample drawing with this print problem?
Re: Can´t print
Post by andrew » Mon Aug 18, 2014 9:47 am
Please refer also to this thread for detailed printing instructions:
http://qcad.org/rsforum/viewtopic.php?f=32&t=2800
In a nutshell, you'll have to switch to print preview first and adjust the paper size, drawing scale and position.
