Import dxf and Bitmap-files
romannachbauer
Post by romannachbauer » Mon Sep 01, 2014 10:15 am
Hello
I uns the QCAD-Version 3.4.7.0 BuildDate Apr 9 2014
What must I do that I can import DXF und bmp files.
I can only import SVG-files
best regards vom switzerland
Roman Nachbauer
Re: Import dxf and Bitmap-dateien
Post by andrew » Mon Sep 01, 2014 10:25 am
romannachbauer wrote:What must I do that I can import DXF und bmp files.
To merge a DXF file into an existing drawing, you can either:
- Use the library browser (View > Library Browser), typically used to insert symbols and other small ready-made parts
- Open both drawings and use copy / paste to copy one drawing into another one
To insert bitmaps (BMP, PNG, JPEG, ...), you can use Draw > Insert Bitmap.
romannachbauer
Post by romannachbauer » Mon Sep 01, 2014 10:42 am
thank you for the quick answer
Roman Nachbauer
romannachbauer
Re: Import *.CAD
Post by romannachbauer » Mon Sep 01, 2014 10:55 am
Hallo
One more question to import files.
Is it possible to import *.cad files ?
thank you
roman nachbauer
Re: Import *.CAD
Post by andrew » Mon Sep 01, 2014 11:05 am
romannachbauer wrote:Is it possible to import *.cad files ?
No. Depending on the application they originate from, you might be able to export them as DXF or convert them to DXF.
