ISO Projection 'Left', odd behaviour !
Moderator
Post by Clive » Tue Oct 28, 2014 11:54 am
When projecting more than six shapes with arc to a 'Left' projection the arc on the chosen reference side doesn't project properly!
* Seems to be the case when projecting more than six
* Seems to be a problem with 'Left' projection only.
iso projection test.png (18.54 KiB) Viewed 4753 times
Adding more shapes increases the number of ill projected arcs!
iso projection test pic 2.png (4.43 KiB) Viewed 4753 times
Test File:
iso projection test.dxf
(89.55 KiB) Downloaded 362 times
Re: ISO Projection 'Left', odd behaviour !
Post by andrew » Tue Oct 28, 2014 1:53 pm
Thanks for the report. This appears to be caused by relatively large coordinates which produce huge intermediate values in an internal algorithm.
A quickfix is available from:
https://raw.githubusercontent.com/qcad/ ... orithms.js
This file replaces <QCAD installation directory>/scripts/ShapeAlgorithms.js
Moderator
Post by Clive » Wed Oct 29, 2014 10:52 am
Thanks Andrew for the quick fix, however I don't seem to be able to copy and paste to replace exsisting script :cry:
Post by andrew » Wed Oct 29, 2014 11:06 am
Clive wrote:Thanks Andrew for the quick fix, however I don't seem to be able to copy and paste to replace exsisting script :cry:
Do you mean in the browser? That's odd.
Maybe something like File > Save page as would work?
Post by andrew » Wed Oct 29, 2014 11:09 am
You can also try it from this page:
https://github.com/qcad/qcad/blob/maste ... orithms.js
Right-click on the 'Raw' button and choose Save as, Save link as, Download liked files as or something similar, depending on your browser.
Moderator
Post by Clive » Wed Oct 29, 2014 11:22 am
Thanks Andrew, I've got it now and can confirm that all is working fine now, thanks again.
