Text and arrow heads are huge on a dwg
HypergolicPop
Post by HypergolicPop » Thu Oct 30, 2014 10:38 pm
3.7.0, MacBook Pro 10.7.5
Opening a dwg file and see huge text and arrowheads.
The dwg file is a FEMA Storm Room. See: https://www.fema.gov/media-library/asse ... 15?id=5788
Huge Text and Arrow Heads
Problem (Screen capture): https://drive.google.com/open?id=0B84lO ... authuser=0
Source: http://www.fema.gov/media-library-data/ ... an_rev.dwg
Any ideas on how to fix it?
The workaround I have found is to use Teigha® File Converter to convert from dwg to dxf. See: http://www.opendesign.com/guestfiles/te ... econverter
TIA,
Hypergolic Pop :)
Re: Text and arrow heads are huge on a dwg
Post by Husky » Fri Oct 31, 2014 12:40 am
Hello Hypergolic Pop,
all of your links are not working for me - I've not the required permission - access denied :(
Could you please attach the dwg (or dxf) to this post? Thank you!
Edit: Never mind! By now I was able to download the file directly from fema.gov
They used for the "Dimension Settings" a "Size scale Factor" of 40 - I changed it to 1.
You can find this setting below: Menu: Edit / Drawing Preferences
... and here is my modified file. :wink:
320_ag_06plan_rev_mod.dwg
(56.57 KiB) Downloaded 405 times
Will that work for you?
HypergolicPop
Post by HypergolicPop » Fri Oct 31, 2014 2:36 am
Thanks!
I bought the book so I guess I should read it. ;-)
Post by Husky » Fri Oct 31, 2014 8:21 am
HypergolicPop wrote:Thanks!
You are welcome!
I think the book is really good - it will help you to overcome many obstacle. The rest is just learning by doing ... :wink:
If you need further help please don't hesitate to post your question in this forum. In the majority of cases somebody has an answer.
