Don´t see or print Hatched areas. Dwg from Autocad.
juanjillo
Post by juanjillo » Fri Oct 31, 2014 11:43 am
Hello all.
We are evaluating this software to avoid the expensive Autocad LT licenses.
The first thing that i see in the software, is that not show the hatched areas and, of course, don´t print it. The lines (for example the axes line) are printed and showed differente in autocad or qcad.
See the image.
I´m missing something?
Kindest regards.
Re: Don´t see or print Hatched areas. Dwg from Autocad.
Post by andrew » Fri Oct 31, 2014 12:20 pm
Thanks for your report.
Please attache or e-mail the drawing file (DXF, DWG), so I can help effectively. Thanks.
