Dashed lines not visualised in print preview
Tillmann
Post by Tillmann » Tue Nov 04, 2014 6:24 pm
QCAD version: 3.7.0
- Build Date: Oct 23 2014
- Qt Version: 4.7.4
OS: Windows 7 64bit
_________________
Hello again,
here another issue. When I set lines as dashed and then get the print preview the lines are not dashed but straight lines.
I hope the bug gets fixed.
Thank you.
Tillmann
Re: Dashed lines not visualised in print preview
Post by andrew » Tue Nov 04, 2014 7:55 pm
Please attach or e-mail the drawing files if possible, thanks.
Tillmann
Post by Tillmann » Wed Nov 05, 2014 6:13 pm
I've attached one DWG-file.
Here are two images which should show how it looks like.
Default view
Print Preview
GE_3-3_01.dwg
(180.24 KiB) Downloaded 359 times
Post by andrew » Thu Nov 06, 2014 9:46 am
Thanks. This seems to be a problem that has been fixed for the next release which is scheduled for today or tomorrow.
Post by andrew » Fri Nov 07, 2014 11:03 am
QCAD 3.7.1 has been released which should fix this problem.
