help with offset
help with offset
I think this is self explanatory. I tried to create a 0.125 offset on the outside of my object. What did I screw up?
Richard
Richard
- qcad_offset1.png (124.04 KiB) Viewed 8466 times
Re: help with offset
Hallo Richard - welcome to the forum!
Could you please attach the dxf. Thanks!
Right now I don't think that you screwed up!rray wrote:What did I screw up?
@Richard
Thanks for the dxf.
Long story short - I think that is a bug!
I tested your drawing and figured out that if I use an Offset value (e.g. 0.064) which is less than the length value of this little vertical line - it will work as expected.
A value higher than the length of this vertical line (e.g. 0.125) will fail.
I also tested this behavior on a new drawing - same result!
@Andrew
What do you think?
Thanks for the dxf.
@Andrew
What do you think?
Any updates or new procedures?
The current algorithm does not support that kind of shape.
Long term, QCAD might switch to an alternative algorithm altogether, possibly something based on an existing library.
Thank you for the update
Just a quick update: this will likely be improved with one of the upcoming releases:
WOW, that is a great Christmas present!
Beautiful!andrew wrote:Just a quick update: this will likely be improved with one of the upcoming releases:
