Tool settings Shortcut problem ...
Post by Husky » Sun Nov 16, 2014 8:08 am
XP / 3.7.1
I like to customize my Tool Shortcuts a bit (Application Preferences/Tool Settings) but it doesn't works as expected.
1.
If I try to use a Shortcut combination like Ctrl+Tab QCAD does not accept the Ctrl Key. Is that just my system or is that in general the case?
2.
For the Tool "Restrict Orthogonally" I supplemented the "Tab" Key to trigger the function - works perfect!
For the Tool "Restriction Off" I supplemented the "Shift+Backtab" combination - doesn't woks at all. What I'm doing wrong?
Moderator
Re: Tool settings Shortcut problem ...
Post by Clive » Mon Nov 17, 2014 2:22 pm
Hey Husky
Try Ctrl+Tab instead, just set up my QCAD for this ... good idea here :wink:
Post by Husky » Mon Nov 17, 2014 9:11 pm
Clive wrote:Hey Husky
I don't know why - but now it's working. Thanks Clive!
I used also the Keyboard Arrow Keys for the vertically and the horizontally restriction - works great! :wink:
Moderator
Post by Clive » Mon Nov 17, 2014 10:35 pm
Husky wrote:I don't know why - but now it's working. Thanks Clive!
Glad it's working now 8)
Husky wrote:I used also the Keyboard Arrow Keys for the vertically and the horizontally restriction - works great! :wink:
Great , makes sense to me,I'm going to set mine up like this as well :) .
