DXF/DWG file cannot be opened in application XY
Post by andrew » Thu Nov 27, 2014 8:12 am
From a QCAD user:
I have troubles loading DXF/DWG files produced by QCAD with other applications.
Re: DXF file cannot be opened in application XY
Post by andrew » Thu Nov 27, 2014 8:15 am
Using QCAD Professional
First, please check that you are using QCAD Professional and not the free QCAD Community edition. You can check this under Help > About or QCAD > About QCAD:
Screen Shot 2017-11-21 at 08.50.57.png (194.3 KiB) Viewed 3730 times
QCAD Professional offers much superior DXF/DWG compatibility.
DXF/DWG Format Versions
Keep in mind that there are various different versions of the DXF/DWG format. You can configure the default DXF/DWG format version that QCAD uses under Edit > Application Preferences > File > Open/Save > Default format. Check which format version is supported by the application you are using to import the file and export to that format version in QCAD. Older format versions typically yield better compatibility, especially with older software products. You might want to use File > Save As... to export your drawing in different format versions using separate file names (mydrawing_r12.dxf, mydrawing_r18.dxf, etc.).
talsit
Post by talsit » Thu Nov 27, 2014 2:46 pm
Hi, I'm that user.
I have upgraded to the latest, and the problem still persists.
Moderator
Post by Clive » Thu Nov 27, 2014 3:04 pm
Hi talsit and welcome
Are you able to submit an example of a troublesome dxf file for testing?
What other applications are you using to open the 'QCAD' created dxf files?
Post by andrew » Sat Nov 29, 2014 4:53 pm
talsit wrote:I have upgraded to the latest, and the problem still persists.
The QCAD version is not the problem. The problem is the DXF/DWG file version when saving. Please refer to my previous post for details. Thanks.
