Key not found ?
J-J
Moderator
Key not found ?
Post by J-J » Tue Dec 02, 2014 10:05 am
I just updated to 3.7.4. After making some changes to a drawing I clicked the save icon and got a"key not found" message. No alternative other than quitting QCAD and discarding changes. Only after a third restart was I able to proceed.
The first time it happened, I had made a search for duplicate, may not have any connection, but I thought I'd mention it. (Win7-64)
JJ Win7 pro-64
Re: Key not found ?
Post by andrew » Tue Dec 02, 2014 4:08 pm
This looks like an error from the Teigha library. Can you attach or e-mail the file? Thanks.
J-J
Moderator
Re: Key not found ?
Post by J-J » Tue Dec 02, 2014 9:23 pm
To try to reproduce the problem:
1- open "vérin-M10_H41x55_ensemble.dxf"
2 - open: 27701-01812_0_view_5.dxf"
3 - from drawing #2 select all and copy with reference in drawing 1
Trying to save drawing 1 with a new name returns the error and saving cannot be done.
Hope you can reproduce it :!:
dxf #2
(30.7 KiB) Downloaded 386 times
dxf # 1
(124.47 KiB) Downloaded 402 times
JJ Win7 pro-64
Re: Key not found ?
Post by andrew » Tue Dec 02, 2014 11:46 pm
Thanks, yes. The problem is with copying linetypes of layers over.
This has been fixed for the next release.
J-J
Moderator
Re: Key not found ?
Post by J-J » Wed Dec 03, 2014 9:08 am
You know your baby :wink:
JJ Win7 pro-64
Re: Key not found ?
Post by andrew » Wed Dec 03, 2014 10:01 pm
This should be solved in the latest release (3.7.5).
J-J
Moderator
Re: Key not found ?
Post by J-J » Wed Dec 03, 2014 10:16 pm
3.7.5 up and running. No problem with my test files.
JJ Win7 pro-64
Re: Key not found ?
Post by andrew » Wed Dec 03, 2014 10:24 pm
OK, thanks for letting me know.
