[solved] Unable to print
Brianparramore
Post by Brianparramore » Thu Dec 18, 2014 11:45 pm
windows 7 Professional, Q Cad 3.2.1.0 unable to print drawings to printer or to pdf file. This problem arose recently, I assume I inadvertently altered some setting. I have reloaded Q Cad, but the problem persists.
Re: Unable to print
Post by andrew » Thu Dec 18, 2014 11:50 pm
Please check out our detailed printing instructions at:
http://qcad.org/rsforum/viewtopic.php?f=32&t=2800
If you're still experiencing problems, please let me know at what step, include screenshots or attach your drawing if possible. Thanks.
Brianparramore
Re: Unable to print
Post by Brianparramore » Thu Jan 08, 2015 4:38 pm
Nothing I have tried has solved the problem. The print function does seem to work, but the page comes out blank. When I try to print to a pdf the file is empty.
Re: Unable to print
Post by andrew » Thu Jan 08, 2015 4:40 pm
Please attach or e-mail your drawing, so I can help effectively, thanks.
Brianparramore
Re: Unable to print
Post by Brianparramore » Mon Jul 18, 2016 9:42 pm
Cured the problem. The paper size was set to hectares.
