Snap possibility's to dimension
Hmmmmmmmmmm, I am confused.
Has something changed in the possibility to snap to dimensions? I'm trying to align a couple dimensions but I'm only able to snap to dim references. Did I missed something?
Re: Snap possibility's to dimension
Yes, snapping to dimension internal shapes has been disabled.
The reasons being:
- performance for drawing with lots of dimensions
- undesired / accidental snapping to dimension line end points with a small gap to an endpoint (you almost always want to snap to the edge end point, not the dimension line end point)
The reasons being:
Ok - makes sense! But here is what has absolutely confused me:andrew wrote:Yes, snapping to dimension internal shapes has been disabled.
The reasons being:
When I create a new Dimension (e.g. Horizontal) I can use a "Free Point" to determine the "Dimension Line Location". This Free Point can be everywhere on the x coordinates of the Dimension Line. But if I need to use this reference point to align the next dimension (e.g. a chain dimensioning) - it is a pain in the back to find this Reference point.
Now - after playing around and by accident I figured that the Reference point for the Dimension line should be always at the same position in the internal shape. I'm correct?
Yes - that would make sense to me ...
... but my problem is that this only works after saving and reloading the whole drawing. Very unpractical - is that intended to work that way?
Yes, that's correct. You can use any point to define the position of the dimension line. However, the DXF / DWG format resets that position, as you have observed. Usually, the exact position of that reference point is irrelevant, only its vertical position matters (for a horizontal dimension).
What means "the exact position of that reference point is irrelevant? I need to snap to it what means I need exactly to know where it is! My Autosnap can't find this point - is there any single snap which will find this reference of the Dim Line? Or do I need to change some kind of Snap settings?andrew wrote:Usually, the exact position of that reference point is irrelevant, only its vertical position matters (for a horizontal dimension).
I'm pretty sure this must be a sort of misunderstanding on my side! Please - enlighten me how to align properly dimensions lines with the example above.
I will not use Grid, I will not use a construction line oslt, I will not have to save and reload the drawing during my work just to get the Reference points reseted.
It can't be that complicated just to make a second Dim and tell it where to place the Dim Line precisely regarding to an other Dim Line ....
Here an example. For demonstration purpose I chose to place the first reference point for the DIM Line extremely to the right side.
However - I'm not able to find / or snap to the first DIM Line as a reference for the second DIM.
Hi Husky
Just tried this, no problems for me.
1.Autosnap on, set first extension line origin.
2.Autosnap on, set second extension line origin.
3.Free snap, set dimension line location at far right.
4.Autosnap back on, second dimension line placed without problems , snapping to reference point on first dimension.
(* Latest QCAD release used).
Hey Husky
Have you set snap to 'Reference points' in your snap settings?
Hi Clive,
I also reinstalled QCAD with a fresh installation / and a fresh QCAD INI - still the same problem.
I'm not sure when Andrew changed the snap possibility for dimension - and I think his intention to change it is absolute reasonable - but now I'm challenging this problem and I have no idea how to solve it.
Thanks for testing! Now I know it should work - but unfortunately it doesn't works on my XP machine.Clive wrote:Just tried this, no problems for me.
Yep, I did.Clive wrote:Have you set snap to 'Reference points' in your snap settings?
Hi Husky
I see Andrew has applied a fix for this:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1150
