divide tool
J-J
Moderator
divide tool
Post by J-J » Tue Jan 27, 2015 10:13 pm
I installed 3.7.7 and I'm faced with a stubborn divide tool when I want to use it to break a circle, it just won't work as before. has anybody noticed such a problem? (Win7-64)
JJ Win7 pro-64
Re: divide tool
Post by andrew » Tue Jan 27, 2015 10:40 pm
Thanks, I can confirm that.
Bug report and quick fix are available at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1174
J-J
Moderator
Re: divide tool
Post by J-J » Wed Jan 28, 2015 7:32 am
Thanks Andrew, aal set :wink:
JJ Win7 pro-64
lightuser
Re: divide tool
Post by lightuser » Thu Feb 12, 2015 4:15 pm
Thanks for issuing the fix Andrew.
Can you direct me to a link that will run me through how to perform this .js edit on the installed 3.7.7? I did one a while ago but the memory has gone!
Many thanks, Tim
Re: divide tool
Post by andrew » Thu Feb 12, 2015 4:30 pm
Meanwhile 3.8 is available with the fix applied in your download area:
http://www.qcad.org/en/customer-area
