3.8 crashes when opening default template
J-J
Moderator
Post by J-J » Thu Feb 05, 2015 10:44 pm
Just installed 3.8 on Win7
I use a default template with a set of predefined layers that is launched via the command line. For some reason, the new version does not like it, QCAD stops working and closes, even if I try to open the template drawing after starting QCAD without it. Older drawings seem to open fine, albeit they were created from that template. e_confused
Any idea ?
nouveau_dessin.dwg
(16.88 KiB) Downloaded 327 times
JJ Win7 pro-64
Re: 3.8 crashes when opening default template
Post by andrew » Fri Feb 06, 2015 9:16 am
J-J
Moderator
Post by J-J » Fri Feb 06, 2015 9:39 am
Same behavior if you invoke "file, new from template"
JJ Win7 pro-64
Post by andrew » Fri Feb 06, 2015 3:12 pm
A bug fix release (3.8.1) is now available.
J-J
Moderator
Post by J-J » Fri Feb 06, 2015 8:46 pm
Yes, ça marche, thanks Andrew :)
JJ Win7 pro-64
