Icons missing in left toolbar
peter76
Post by peter76 » Thu Feb 12, 2015 6:04 pm
I'm using QCad 3.8.1 professional on OS X 10.9.5 .
I was doing some drawing today and noticed that there's no icon for making a block anymore in the left toolbar.
Also when I click on the icon for projection tools in the left toolbar, an empty toolbar shows up.
Everything is in the menu's though.
Is this a bug, or can I fix this somehow?
Regards, Peter
Re: Icons missing in left toolbar
Post by Husky » Thu Feb 12, 2015 7:31 pm
Hello Peter,
you can customize the visibility/invisibility of Icons by yourself.
Please check the Application Preferences below: Edit / Application preferences / Tool Settings
peter76
Post by peter76 » Thu Feb 12, 2015 8:20 pm
Hi Husky,
Thanks for the reply.
I tried those options, but when I turn them on I get an icon which is on top of the "line" and "points" icons.....
Starting to guess it's a bug
Regards, Peter
Post by Husky » Thu Feb 12, 2015 8:38 pm
peter76 wrote:I tried those options, but when I turn them on I get an icon which is on top of the "line" and "points" icons.....
Yes you are right - looks weird ....
peter76 wrote:Starting to guess it's a bug
Me too!
@Andrew
Any suggestion on this?
Post by andrew » Fri Feb 13, 2015 9:19 am
The tool you are looking for is likely not the Create Block tool from example scripts but the Block > Create Block from Selection tool:
Screen Shot 2015-02-13 at 09.15.21.png (128.77 KiB) Viewed 6974 times
If you cannot fix your configuration, you can reset it by deleting the QCAD configuration file:
- Open Finder
- Choose menu Go > Go to Folder...
- enter ~/.config/QCAD
- Click OK
- Delete file QCAD3.ini
Post by Husky » Fri Feb 13, 2015 9:54 am
andrew wrote:The tool you are looking for is likely not the Create Block tool from example scripts but the Block > Create Block from Selection tool:
Ouch! Busted! :oops: :wink:
peter76
Post by peter76 » Fri Feb 13, 2015 8:05 pm
Hi Andrew, thanks for pointing out the difference between the two options:-)
The " looking weird" thing goes away once I restart QCad!
Als good to know you can reset everything by deleting the .ini file
regards, Peter
