Qcad 3.9 Library Browser updates everything
Alchemist45
Post by Alchemist45 » Mon Apr 13, 2015 7:27 pm
For some reason my library wants to update all entries any time it updates. This takes a long time! I thought that it would only update changed entries and thus be very fast if nothing was changed. Is there any way to store the library information and use that unless you want to update because you have changed a library item?
Thanks for any help or advice. Waiting for 5000+ items to scan each time you access the library anew is pretty tiresome!
Re: Qcad 3.9 Library Browser updates everything
Post by andrew » Tue Apr 14, 2015 7:58 am
It's not actually updating everything but checking what needs to be updated. This is only possible by looking at every file and directory, since every file and every directory might have changed or been deleted.
You can configure this behavior in Edit > Application Preferences > Widgets > Library Browser
Screen Shot 2015-04-14 at 08.56.29.png (104.13 KiB) Viewed 8642 times
You can than synchronize manually by clicking the button at the bottom right in the Library Browser:
Screen Shot 2015-04-14 at 08.58.47.png (65 KiB) Viewed 8642 times
Alchemist45
Post by Alchemist45 » Tue Apr 14, 2015 4:07 pm
Ok. Thanks. I believe I understand, so maybe just a suggestion. If I know I haven't changed any libraries, it would be nice if the old info was saved so I could use them without the lengthy update each time I want to access a library after a fresh start of qcad. What do you think?
Alchemist45
Post by andrew » Tue Apr 14, 2015 4:26 pm
Yes, hence the preference to switch the updating off (see my previous post).
