Am using a QCAD pro version 3.7.6.0 I did a drawing with all the dimensions and saved it. The next day when I opened the latter to continue working on it, there were a lot of dimensions missing. Each time i save and close a drawing, when i reopen it there are dimension missing. how can this be resolve??
Reagrds,
Neshen
Missing dimensions when opening an existing drawing
Re: Missing dimensions when opening an existing drawing
Am still having the dimension issue with my QCAD pro version 3.7.6.0 and till now have not got any solution for the problem??
Is there any other place/forum where i could post this isssue??? is in related to the software???
You are very likely referring to bug FS#1167 which was fixed in QCAD 3.7.7.
