Missing dimensions when opening an existing drawing
neshen
Post by neshen » Fri Apr 24, 2015 6:58 am
Am using a QCAD pro version 3.7.6.0 I did a drawing with all the dimensions and saved it. The next day when I opened the latter to continue working on it, there were a lot of dimensions missing. Each time i save and close a drawing, when i reopen it there are dimension missing. how can this be resolve??
Reagrds,
Neshen
neshen
Re: Missing dimensions when opening an existing drawing
Post by neshen » Tue May 05, 2015 9:20 am
Am still having the dimension issue with my QCAD pro version 3.7.6.0 and till now have not got any solution for the problem??
Is there any other place/forum where i could post this isssue??? is in related to the software???
Post by andrew » Tue May 05, 2015 9:42 am
You are very likely referring to bug FS#1167 which was fixed in QCAD 3.7.7.
