(solved) Cannot load library items with3.9.2
J-J
Moderator
Post by J-J » Tue May 12, 2015 1:54 pm
Both teh main station and laptop run on Win-7-64, pro. Iwas using the latest release but I could no longer insert many of my usual library items. I reverted back to 3.9.1 on the laptop, and library item are usable again... e_confused
Anyone noticed any thing?
JJ Win7 pro-64
Re: Cannot load library items with3.9.2
Post by andrew » Tue May 12, 2015 2:16 pm
Yes, there is a known issue with paths on some Windows installations. This will be fixed for the next release.
J-J
Moderator
Post by J-J » Tue May 12, 2015 4:30 pm
An identified problem is half way solved, I'll wait with 3.9.1. :wink:
JJ Win7 pro-64
Post by andrew » Wed May 13, 2015 12:37 pm
This is likely fixed in QCAD 3.9.3 released today. Please let me know if not, I wasn't able to reproduce the problem here, so it seems to affect only some Windows installations.
J-J
Moderator
Post by J-J » Wed May 13, 2015 3:58 pm
I made a few quick tests with 3.9.3 and so far, so good :D
Thanks for the quick fix.
JJ Win7 pro-64
