(solved) Pan mouse cursor when using trackpad
Post by andrew » Mon Jun 01, 2015 1:38 pm
From a QCAD user:
When using a drawing tool (for example line with two points), instead of the crosshairs cursor, a little hand (panning) appears.
Re: Pan mouse cursor when using trackpad
Post by andrew » Mon Jun 01, 2015 2:31 pm
You have likely enabled the pan gesture. You can disable it under Edit > Application Preferences > Graphics View > Navigation:
Screen Shot 2015-06-01 at 15.30.20.png (125.51 KiB) Viewed 2685 times
