SVG not visible in Inkscape after export from QCAD3
TinselRN
Post by TinselRN » Mon Jun 15, 2015 2:10 pm
I have removed the layers from a complex .dwg to leave the 5 layers I require using QCad Pro (3.9.4.1).
I then carried out an .svg export but the resulting file is 'blank' when viewed in preview or opened with Inkscape.
It is a simple line drawing produced on the following system:
MacBook Pro Rretina
13-inch
2.8GHz Intel Core i5
OSX 10.10.3
Can you offer a solution?
Many thanks,
David
Re: SVG not visible in Inkscape after export from QCAD3
Post by andrew » Mon Jun 15, 2015 2:20 pm
Thanks for your report.
- attach original drawing files (DXF, DWG, ...) if appropriate
- attach exported files (SVG, PNG, PDF, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message
Please be as specific as possible in describing your problem, so we can help you efficiently.
Thanks.
