Saving Dialog Box Warning
I keep getting the attached dialog box and it does not make sense to me. It seems to warn that it is saving in an older Autocad version format but I fail to understand why it comes up. Even if I save a file in R17 the next time I save the file again this dialog box appears again.
- Screen Shot 2015-08-18 at 19.04.16.png (71.95 KiB) Viewed 3573 times
Re: Saving Dialog Box Warning
If you're not worried about 24bit colors, you can switch the warning off under
Edit > Application Preferences > Load/Save > Save As
The warning should only be displayed when saving to DXF R15 or older. Note that if you load an R15 drawing and then use File > Save, the file format version will still be R15 and the warning will be shown.
