draw arc option
a l e x
draw arc option
Post by a l e x » Fri Sep 18, 2015 7:57 am
in version 3.10,
for the arc tool with center,point,angles (AR),
the option toolbar does only show one of two directions.
Both were available in the past ( v 3.5 )
Alex
Re: draw arc option
Post by Husky » Fri Sep 18, 2015 8:45 am
Hello Alex,
a l e x wrote:Both were available in the past ( v 3.5 )
They should be still available - this is what I see in my 3.10 option bar for AR
a l e x
Re: draw arc option
Post by a l e x » Fri Sep 18, 2015 9:33 am
Indeed, I can also see this- when the toolbar is docked.
However, when it is floating, the second direction is replaced by a double arrow...
a l e x
Re: draw arc option
Re: draw arc option
Post by andrew » Fri Sep 18, 2015 9:48 am
Please don't float the options toolbar. The options tool bar is dynamically showing different sets of widgets and unfortunately the Qt tool kit does not handle this properly when the tool bar is undocked.
a l e x
Re: draw arc option
Post by a l e x » Fri Sep 18, 2015 11:50 am
Floating toolbar works well almost all the time.
For example with "arc of length " (AL), you do have two directions available.
