[solved] Qcad 3.12.0 disappears blocks
S.O: ubuntu 14.04
in qcad 3.12.0 when i move or rotate blocks they disappears and reamain only the reference point. block name disappears in specific proprieties menu and i can select it in block list. It 's frequently but not every time. I reinstall 3.11.3 and all is normal.
Re: Qcad 3.12.0 disappears blocks
Thanks for your report.
Do you have a file which can be used to demonstrate the problem? Thanks.
Yes i have a file but if i close the file after the block lost, the block reference point not already exist.
this is the terminal output when the block disappears and after when i select it from property editor-specific propierty-Block.
It happened if i rum qcad from terminal too!
bigger block more frequently lost
Where I attach the file?
Warning: RBlockReferenceData::applyTransformationTo: block -1 is NULL
Debug: TIMER: 8000000 ns ( 8 ms ) - "painting"
You can find detailed step by step instructions for attaching files at:mitch37 wrote:Where I attach the file?
viewtopic.php?f=47&t=3760
it's a file where it happened. the block pt001 just dissappears
- gardo_house_bug001.dxf
- (926.69 KiB) Downloaded 321 times
Thanks. Do you have steps to reproduce the problem? For example:
1. insert block "pt001"
2. select block reference
3. user tool ...
etc.
Thanks again.
3. user tool ...
etc.
Thanks again.
yes
1. select all
2. create block
3. click reference point
4. waiting the creation of the block
5. select block
3. move the block many time with move and delete original (with this file 8 times move randomly)
4 block dissappears.
I've this bug in two pc ubuntu 14.04 64bit
1. select all
2. create block
5. select block
Thanks. I didn't have any success so far to reproduce this.
Would it be possible for you to send me the entire output of a session in which the block disappears? You can stream the output to a file like this:
This creates the file log which you can attach here or e-mail to andrew at qcad dot org. Thanks again.
./qcad 2>log
here is the file log
thanks
thanks
- log.txt
- (7.1 KiB) Downloaded 338 times
Many thanks, this was most helpful. I've issued a bug report at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1292
The problem has been fixed for the next minor update.
ok, i came back 3.11.3 until next release.
thanks
thanks
A bug fix release is now available: 3.12.1
great job!!!!
thanks
thanks
