how to select the proper format
gershon09
Post by gershon09 » Wed Nov 11, 2015 3:59 pm
I was using librecad and i switched to qcad. When i try to save my file i get such kind of message:
File format is not good: R15 2000 dxg trawing teigha
And then other notes mentioning that there will be positive/negative issues...
So i should change format, but when i want to save a file, the only format possible is "R15 2000 dxg trawing teigha".
How to get the proper format? And which format is the good one ?
gershon09
Re: how to select the proper format
Post by gershon09 » Wed Nov 11, 2015 4:30 pm
I forgot to give the version of my qcad:
3.12.0.0 (3.12.0)
gershon09
Post by gershon09 » Wed Nov 11, 2015 5:38 pm
I just installed qcad on the computer of my work. I opened the job done at home, saved it, and it saves it into the format : R27. And it does not give any error message.
At my job i have the same version of qcad : 3.12.1.0 (3.12.1)
Also, (at my job) i can save it in any format. Why can't i do that home ???
Post by andrew » Thu Nov 12, 2015 9:41 am
Is this QCAD Professional, a QCAD Professional Trial version or the QCAD Community Edition? Thanks.
