Is there a -r (or -x, -y) limit in dwg2bmp? A dwg file I tried to convert to png would work with -r 25, but fails with -r 26.
OS: Linux Fedora 20
QCAD: qcad-3.12.1-pro-linux-x86_64
DWG file: http://download.autodesk.com/us/samplef ... perial.dwg
$ ./dwg2bmp -a -b white -c -f -o architectural_example-imperial.png -r 26 architectural_example-imperial.dwg
Warning: libpng warning: Image width is zero in IHDR
Warning: libpng warning: Image height is zero in IHDR
libpng error: Invalid IHDR data
What would be the best way to work out the maximum -r (or -x, -y) value I can use for a given dwg file? The reason I want the max resolution possible is that I'm passing the generated png to an OCR program for text recognition.
Thanks for your help.
Size limit in dwg2bmp?
Re: Size limit in dwg2bmp?
Yes, there are size limits for bitmaps. Please keep in mind that the bitmap has to be created in 24bit colors and uncompressed before it can be compressed into a much smaller PNG file.manmin wrote:Is there a -r (or -x, -y) limit in dwg2bmp? A dwg file I tried to convert to png would work with -r 25, but fails with -r 26.
The -x and -y values can be used to indicate the desired size of the image and are the same for all drawing inputs. It's a matter of experimentation to find out which values still work on your system (probably somewhere between 20000 and 30000).manmin wrote:What would be the best way to work out the maximum -r (or -x, -y) value I can use for a given dwg file?
This seems like an unnecessary complicated and error prone process to me. Is there any reason why you cannot simply extract the plain text strings from the drawing file?The reason I want the max resolution possible is that I'm passing the generated png to an OCR program for text recognition.
What's the limit based on? Is it a memory limitation? Or some hardcoded limit? I'm just wondering if there's an equation I can use to determine the -x and -y values as I'll be using dwg2bmp in a script to process large numbers of dwg files (so trial and error method is not practical).The -x and -y values can be used to indicate the desired size of the image and are the same for all drawing inputs. It's a matter of experimentation to find out which values still work on your system (probably somewhere between 20000 and 30000).
2 reasons:This seems like an unnecessary complicated and error prone process to me. Is there any reason why you cannot simply extract the plain text strings from the drawing file?
1) I don't know how to retrieve the text from the dwg. Is there any tool in qcad that would allow me to do that?
2) The ocr process also retrieves the position of the text in the image, and this allows me to highlight the text when the image (from dwg2bmp) is presented to the user. I'm open to suggestions if there are any tools in qcad that would allow me to do that.
Thanks again for your help.
It's a limit imposed by the underlying libraries that are used to create the output file. Note that a 30000x30000 pixel bitmap takes up 30000x30000x4 Bytes of memory (~3.5GB).What's the limit based on? Is it a memory limitation? Or some hardcoded limit? I'm just wondering if there's an equation I can use to determine the -x and -y values as I'll be using dwg2bmp in a script to process large numbers of dwg files (so trial and error method is not practical).
It's certainly possible to extract this information using the script interface of QCAD, yes. It would require some script development (in JavaScript).1) I don't know how to retrieve the text from the dwg. Is there any tool in qcad that would allow me to do that?
Here's how I would likely approach this problem:2) The ocr process also retrieves the position of the text in the image, and this allows me to highlight the text when the image (from dwg2bmp) is presented to the user. I'm open to suggestions if there are any tools in qcad that would allow me to do that.
- Extract all texts in a DWG/DXF into a simple XML or JSON file containing all text strings and their bounding boxes (in pixels referring to the bitmap).
- Use the bitmap and XML file together to look up texts and their positions.
Could you please point me to any documentation where I can get started.It's certainly possible to extract this information using the script interface of QCAD, yes. It would require some script development (in JavaScript).
That was the planned approach, but using an ocr tool. Doing it without the latter would be a much better approach. Thank you.Here's how I would likely approach this problem:
Here's a simple, rough example you can use as starting point. This should solve the most crucial problems (creating a bitmap, extracting texts and bounding boxes mapped to pixels).
Save the file for example to scripts/Tools/ExtractTextInfo of your QCAD installation.
Then you can run it with:
Note that this is by no means a complete solution. You might want to customize bitmap parameters, extract also text from blocks, etc.
./qcad -autostart "scripts/Tools/ExtractTextInfo/ExtractTextInfo.js"
include("scripts/library.js"); include("scripts/Tools/arguments.js"); include("scripts/File/BitmapExport/BitmapExportWorker.js"); function printHelp() { print("Usage: " + args[1] + " [OPTIONS]... <drawing file>"); print(); print("Extracts information from a drawing file (DWG, DXF, ...)."); print(); print(" -f, -force Overwrite existing output file"); print(" -o FILE, -outfile=FILE Set output file to FILE"); print(" default is same path and base name as input file"); print(); } /** * \return RBox, mapped to view coordinates (pixels) */ function mapBoxToView(view, box) { return new RBox(view.mapToView(box.getMinimum()), view.mapToView(box.getMaximum())); } function main() { if (testArgument(args, "-h", "-help")) { printHelp(); return; } if (args.length < 3) { print("No input file given. Try -h for help."); return; } var cadFile = args[args.length - 1]; if (cadFile.indexOf("-") === 0) { print("No input file. Try -h for help."); return; } var fi = new QFileInfo(cadFile); if (!fi.isAbsolute()) { cadFile = RSettings.getLaunchPath() + QDir.separator + cadFile; fi = new QFileInfo(cadFile); } // get bitmap output name from command line: var bmpFileName = getArgument(args, "-o", "-outfile"); if (bmpFileName!==undefined) { if (!new QFileInfo(bmpFileName).isAbsolute()) { bmpFileName = RSettings.getLaunchPath() + QDir.separator + bmpFileName; } } else { bmpFileName = fi.absolutePath() + QDir.separator + fi.completeBaseName() + ".bmp"; } if (new QFileInfo(bmpFileName).exists() && !testArgument(args, "-f", "-force")) { print("Output file exists already, not overwriting: ", bmpFileName); print("Use -f to force overwrite"); return; } // see BitmapExportWorker.js var properties = []; // create document: var storage = new RMemoryStorage(); var spatialIndex = new RSpatialIndexNavel(); var doc = new RDocument(storage, spatialIndex); var di = new RDocumentInterface(doc); var scene = new RGraphicsSceneQt(di); var view = new RGraphicsViewImage(); view.setScene(scene, false); // load document: if (di.importFile(cadFile) != RDocumentInterface.IoErrorNoError) { di.destroy(); print("Cannot import file:", cadFile); return; } QCoreApplication.processEvents(); print("Converting"); print(" from: " + cadFile); print(" to : " + bmpFileName); var res = exportBitmap(doc, scene, bmpFileName, properties, view); var ids = doc.queryAllEntities(); for (var i=0; i<ids.length; i++) { var e = doc.queryEntity(ids); if (isTextBasedEntity(e)) { qDebug("text:", e.getPlainText()); qDebug("text bb in pixels:", mapBoxToView(view, e.getBoundingBox())); } if (isDimensionEntity(e)) { var td = e.getTextData(); qDebug("dim label:", td.getPlainText()); qDebug("dim label bb in pixels:", mapBoxToView(view, td.getBoundingBox())); } } print("Conversion finished."); di.destroy(); } if (typeof(including)=='undefined' || including===false) { main(); }
This is great - your sample code will give me a head start. Thank you very much for your help.
