Qcad 3.12.4 starts and immediately closes
masterchippy
Post by masterchippy » Mon Dec 14, 2015 8:47 am
Hi using Win 10 64bit.
Just upgraded to the 64 bit version but cannot get it to fully start up. All appears normal, Splash screen then opens the various windows but as soon as they are drawn the program closes have re installed and still no go. Reverting to 3.12.3 32 bit. Any ideas please
J-J
Moderator
Re: Qcad 3.12.4 starts and immediately closes
Post by J-J » Mon Dec 14, 2015 8:58 am
Same behavior, I had to delete the "ini" config file to get it to start. You have to reconfigure...
JJ Win7 pro-64
Post by andrew » Mon Dec 14, 2015 9:38 am
masterchippy: if you could send us or attach the QCAD3.ini file, that would be most helpful to check what is wrong, thanks.
masterchippy
Post by masterchippy » Mon Dec 14, 2015 10:59 am
Not sure how to attach ini file will pm it.
Renaming the ini file worked but of course lost the settings I had lovingly created over time! oh well at least it works.
Thanks loads
Jamie
Post by andrew » Mon Dec 14, 2015 11:27 am
Thanks, this is most helpful.
Bug report created at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1331
Post by andrew » Mon Dec 14, 2015 1:37 pm
I've uploaded new 64bit packages for Windows which should fix the problem (missing DLL). The package version is 3.12.4.1.
masterchippy
Post by masterchippy » Mon Dec 14, 2015 6:33 pm
Thanks.
It installed and ran fine. Renamed the copy of ini file back and have all my settings back aswell.
Again thanks
Jamie
