Something i have trouble with is trimming construction lines back after they have served their purpose. it seams where two lines cross is sometimes recognised and sometimes not. especially when a radius is involved.
is there a way to add an officially sanctioned intersection point manually if the program for some reason fails to do so?
also extend seams to have the same problem, that is how the long construction line comes about in the first place,
when extend refuses to agree that it is going to intersect then a long line is inserted with the intention to trim back but alas
what am i doing wrong with this?
trim and extend
Re: trim and extend
Thanks for your report.
- indicate the operating system you are using and the version thereof
- indicate the exact version of QCAD you are using (see Help > About or QCAD > About QCAD)
- attach original drawing files (DXF, DWG, ...) if appropriate
- include screenshots if appropriate
- if there is an error message, indicate the exact message
