Dualboot Win7/Ubuntu 14.04 LTS (32Bit)
QCAD/CAM Professional 3.13.1.0 (3.13.1)
actual OS: Ubuntu 14.04 LTS
after a while I was trying a new Sketch and was not able to do so.
Lets say, I would like to draw a Line:
I chose a Line and the first thing I realize is, that the SNAP is not working. Command line says "First Point" and I click the first Point but nothing happens.
Then the second Point and nothing. Command line says still "First Point".
Drawing Background is black and Layer is white
A fresh Install under Win7 works?
Ciao
Walter
[Solved] No more Drawing possible
Re: No more Drawing possible
Most likely a configuration issue.
You can reset QCAD to its default configuration by deleting the file QCAD3.ini:
http://www.qcad.org/en/qcad-documentati ... leshooting
[Solved] Re: No more Drawing possible
Hah! Works now
Thank you Andrew
Ciao
Walter
Thank you Andrew
Ciao
Walter
