Templates get deleted on uninstall
linnemann
Post by linnemann » Tue Apr 12, 2016 6:52 am
Hi
The latest versions of QCAD removes my custom templates on uninstall.
I have created a symlink to my templates folder into the original qcad folder.
mklink /D "c:\Program Files\QCAD\libraries\templates" "F:\TEGNINGER\QcadLibrary\Templates"
It did not do this prior to version 3.12
The reason I do this is because I am lazy and there are no way to set the default template directory when using Ctrl+Shift+n
It would be better if the templates settings behave similar to the library folder list, then we can move our own templates folder to the top.
2016-04-12 07_49_06-Untitled 1 - QCAD.png (44.94 KiB) Viewed 4148 times
2016-04-12 07_49_39-Untitled 1 - QCAD.png (66.16 KiB) Viewed 4148 times
