[solved] Hatch pattern preview?
HDK
Post by HDK » Fri Apr 15, 2016 10:36 pm
When hatching an area, the hatch preview mostly shows all white, or an illegible pattern; suggestions? If this is a limitation of the viewer, at least on my system, is there a list of the hatch patterns with graphics?
Hatch problem.tiff
Hatch problem.tiff (39.46 KiB) Viewed 6436 times
Thanks,
David
QCAD 3.14.3.0 on a Mac with OS X Yosemite 10.10.3, 24GB ram
Re: Hatch pattern preview?
Post by andrew » Fri Apr 15, 2016 10:49 pm
You are likely working on a metric drawing which is using imperial hatch patterns or an imperial drawing using metric hatch patterns. Please check if the drawing preferences for units match under:
Edit > Drawing Preferences > General > Drawing Unit
HDK
Post by HDK » Sat Apr 16, 2016 5:52 am
Thanks for the response. I checked the drawing unit settings and when it is set for Inch and Imperial it doesn't work, when I change it to MM and Metric it does.
Drawing Unit-inch.tiff
Drawing Unit-inch.tiff (73.04 KiB) Viewed 6427 times
Drawing Unit-mm.tiff
Drawing Unit-mm.tiff (76.05 KiB) Viewed 6427 times
Since I'm working with Architectural units (feet & inches) the drawing unit needs to be set for Inch not MM.
Post by Husky » Sat Apr 16, 2016 5:32 pm
Hi HDK,
HDK wrote:Since I'm working with Architectural units (feet & inches) the drawing unit needs to be set for Inch not MM.
Is that just me? I can't see your pics on my screen ....
However - this example setting would not work for you?
HDK
Post by HDK » Sat Apr 16, 2016 11:46 pm
Drawing units is set as shown (inch, inch, imperial) and the hatch comes out fine, just will not show up in the viewer.
The screen captures I uploaded were tiff images, perhaps jpg or png would work better...
Post by andrew » Sun Apr 17, 2016 4:52 pm
I can confirm that the preview in the hatch dialog is broken for imperial drawings. The rectangle is too big to make the pattern visible. This has been improved for the next release.
HDK
Post by HDK » Sat May 14, 2016 8:49 pm
Downloaded QCAD v3.14.3 and all is well, thanks for taking care of this problem...
