DXF importing
bvd4
DXF importing
Post by bvd4 » Mon Jun 06, 2016 9:05 am
Version:
3.15.2.0 (3.15.2)
Internet:
QCAD.org
Build Date:
May 30 2016
Revision:
dd761bc
Qt Version:
5.5.1
Architecture:
x86_64
Compiler:
MSVC++ 12.0 (2013)
I am new to Qcad and am having a problem importing a DXF file
I can load the file but 1 of the profiles is missing
If I load the same file in Turbocad all the profiles are there
Any suggestions
Bill
Re: DXF importing
Post by andrew » Mon Jun 06, 2016 9:09 am
Thanks for your report.
- indicate the QCAD Edition you are using (QCAD Professional, QCAD Trial-Version, QCAD Community Edition)
- attach original drawing files (DXF, DWG, ...) if appropriate
- if there is an error message, indicate the exact message
Please be as specific as possible in describing your problem, so we can help you efficiently. Thanks.
bvd4
Re: DXF importing
Post by bvd4 » Mon Jun 06, 2016 9:14 am
I have attached the problem file
You will see a number of profiles on the bottom left corner you will see the letter D there should be a rectangular shape around this letter
BH-O-019-02-PROFILES TEST DXF 2015.DXF
(170.47 KiB) Downloaded 329 times
bvd4
Re: DXF importing
Post by bvd4 » Mon Jun 06, 2016 10:00 am
Also I am using the trial version
bvd4
Re: DXF importing
Post by bvd4 » Mon Jun 06, 2016 10:27 am
Yes I have a dwg file but i can not import the file as I get the following error
Error while importing file C:/Users/Bill/Documents/Bills Stuff/Woodworking stuff/Adirondack chairs/BH-O-019-02-PROFILES TEST DWG.dwg
Re: DXF importing
Post by andrew » Mon Jun 06, 2016 11:53 am
This rectangle is of type "Face" which is not commonly used in 2D drawings. I can confirm that this entity type is currently not supported in QCAD. The other contours are polylines.
Basic support for this entity type will likely be added for the next release of QCAD.
bvd4
Re: DXF importing
Post by bvd4 » Tue Jun 07, 2016 6:24 am
I have just loaded the problem file into Turbocad and drawn around the part that is a problem using a normal line command on a new layer
I then deleted the rectangle that was not being shown and saved the file
If I then try and import this modified file into Qcad everything works correctly
I have another question for you
At present I am using Windows 10 and am not very happy with it
At some stage I intend to change to an Apple Mac
If I buy QcAD for windows now and then change to a Mac at a latter date do I have to buy a new version of Qcad ?
When will the next version of QCAD be released ??
Thanks for your help
Bill
Re: DXF importing
Post by andrew » Tue Jun 07, 2016 8:04 am
bvd4 wrote:If I buy QcAD for windows now and then change to a Mac at a latter date do I have to buy a new version of Qcad ?
No. You can switch operating systems at any time and also use the same QCAD Professional license on multiple computers with multiple operating systems as long as you are the only user. In your download area you can find packages for all supported platforms.
bvd4 wrote:When will the next version of QCAD be released ??
We usually issue a new release about every month.
