I'm evaluating QCAD (I'm acually interested in the command-line tools: dwg2pdf, etc.)) and everything seems to work except for the texts.
My *.DXF files are generated by a custom application and they can be seen correctly in AutoCAD/DXF/DWG Viewers).
I attached such a file (DXF-R12).
I'd also like to mention that other (online) converters work properly with these files (eg dxfconverter.org)... they have another problem (paper size) but that's another story.
Platform is: Win 7 Prof. - 32 bit
QCAD Trial Version: 3.15.2.0 (3.15.2) download from the internet
Any ideas?
Thank you!
Best regards,
Radu G.
dxf r12 - text is wrong
- in_test_qcad.pdf
- qcad exported pdf
- (26.3 KiB) Downloaded 416 times
- in_test.dxf
- input file
- (35.21 KiB) Downloaded 424 times
Re: dxf r12 - text is wrong
Reason for closing: Fixed
Already solved?
Radu G.
Already solved?
Radu G.
