Lengthen problem
duccoder
Lengthen problem
Post by duccoder » Wed Jun 29, 2016 11:12 am
I draw with steps:
1. I draw splinefit with nodes: (31,33) (30, 35) (35, 37)
2. Explode it to polyline
3. Lengthen on end of polyline with amount = 54
4. Lengthen on start of polyline with amount = 54, then I receive below
I have been attach dxf file below. My QCAD: QCAD Pro 3.15.3.0
lengthen_dxf.dxf
(122.33 KiB) Downloaded 431 times
Re: Lengthen problem
Post by andrew » Wed Jun 29, 2016 2:39 pm
Thank you for your report.
Bug report added at:
http://www.qcad.org/bugtracker/index.ph ... sk_id=1441
duccoder
Post by duccoder » Fri Jul 01, 2016 4:49 am
Hi andrew, I saw your fix & release 3.15.4, but seem not update doc for developer
http://www.qcad.org/doc/qcad/3.0/develo ... db613267d9
bool RLine::trimStartPoint	(	const RVector & 	trimPoint,
const RVector & 	clickPoint = RVector::invalid
missing extend param
Post by andrew » Fri Jul 01, 2016 7:45 am
I've updated the online API doc accordingly.
