File format version not recommended
Post by andrew » Fri Jul 15, 2016 3:05 pm
From a QCAD user:
When saving my files, I'm getting a warning message. Should I be worried?
Version not recommended.png (32.89 KiB) Viewed 2993 times
Re: File format version not recommended
Post by andrew » Fri Jul 15, 2016 3:07 pm
Your file is using an old version of the DXF format as indicated by the warning.
To save your file in a newer version of the DXF format, use File > Save As... and choose for example DXF R27:
Screen Shot 2016-07-15 at 16.07.01.png (14.53 KiB) Viewed 2992 times
