Clip to rectangle test query ?
Moderator
Post by Clive » Wed Aug 03, 2016 9:40 am
When using Clip to Rectangle tool I find it's only working in certain instances.
In the screenshot I am using the Yellow squares as my region to clip to and as you can see it doesn't work for me on the larger area? Maybe I'm missing something here or could it be a bug?
*The circles with the cross are actually points -Mode 34, pixel size 50
clip to rectangle test.jpg (85.13 KiB) Viewed 2727 times
Test file attached:
clip to rectangle test.dwg
(19.67 KiB) Downloaded 307 times
Re: Clip to rectangle test query ?
Post by andrew » Wed Aug 03, 2016 10:00 am
