Autosave
tsftom
Autosave
Post by tsftom » Mon Sep 05, 2016 5:33 pm
I'm running Qcad 3.12.1.0 (2015 build) on Linux Mint 17 . Everything works fine but I cannot figure out if Autosave is working properly. It is Enabled in the setup dialog but I cannot find where anything is saved or how to go back to a saved version. Is it saved as a dxf file with .bak extension? Also, I cannot find any settings for directing the saved files to a particular location (path). Is this feature not working on my version? I'd appreciate some advice on this matter.
Tamas
Re: Autosave
Post by andrew » Mon Sep 05, 2016 5:40 pm
Auto save saves your file at intervals using the same path and file name as the loaded file but with a ~ in front of the file name (e.g. /home/user/data/~mydrawing.dxf).
These auto save files are automatically deleted when you save your drawing manually. Should a crash occur, QCAD will ask you if you want to recover the last auto saved version.
If you are looking for a history of your changes or an old version of your drawing, I'm afraid auto save is not the place to look.
In the future, you could use a simple manual versioning system (save as mydrawing001.dxf, mydrawing002.dxf, ...) for this or a full blown version control system such as git or subversion. Needless to say, regular full automatic backups are mandatory for any serious computer user.
