Hi, I have a problem with offset polyline (I use QCAD Pro 3.15.5 on linux)
First, I create polyline (white), then I offset (Modify/Offset) with distance = 0.5 & I receive problem as image
I have been attach dxf file, can you check the problem
Polyline offset bug
Polyline offset bug
- offset.dxf
- (188.68 KiB) Downloaded 336 times
Re: Polyline offset bug
Thanks for your report. Unfortunately, there is no definitive solution to the offset problem (due to the numerical instability of the algorithms involved). The situation can likely be improved by making the algorithm tolerances configurable for a future release.
I see, hope it solved on future
